RTEMS Logo
RTEMS 4.10.1 On-Line Library
Object Services OBJECT_GET_CLASS_INFORMATION - Obtain Class Information
27.4.16: OBJECT_GET_CLASS_INFORMATION - Obtain Class Information
CALLING SEQUENCE:
procedure Object_Get_Class_Information(
   The_API   : in     RTEMS.Unsigned32;
   The_Class : in     RTEMS.Unsigned32;
   Info      :    out RTEMS.Object_API_Class_Information;
   Result    :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES
RTEMS.SUCCESSFUL - information obtained successfully
RTEMS.INVALID_ADDRESS - info is NULL
RTEMS.INVALID_NUMBER - invalid api or the_class
If successful, the structure located at info will be filled in with information about the specified api/the_class pairing.
DESCRIPTION:
This service returns information about the object class indicated by the specified api and the_class. This structure is defined as follows:
NOTES:
This directive is strictly local and does not impact task scheduling.
