RTEMS Logo
RTEMS 4.10.1 On-Line Library
Stack Bounds Checker Checking for Blown Task Stack
25.3.2: Checking for Blown Task Stack
The application may check whether the stack pointer of currently executing task is within proper bounds at any time by calling the rtems.stack_checker_is_blown method. This method return FALSE if the task is operating within its stack bounds and has not damaged its pattern area.
