RTEMS Logo
RTEMS 4.10.1 On-Line Library
Barrier Manager Creating a Barrier
20.3.1: Creating a Barrier
The rtems.barrier_create directive creates a barrier with a user-specified name and the desired attributes. RTEMS allocates a Barrier Control Block (BCB) from the BCB free list. This data structure is used by RTEMS to manage the newly created barrier. Also, a unique barrier ID is generated and returned to the calling task.
