RTEMS Logo
RTEMS 4.10.1 On-Line Library
Region Manager Changing the Size of a Segment
14.3.7: Changing the Size of a Segment
The rtems.region_resize_segment directive is used to change the size in bytes of the specified segment. The size may be increased or decreased. When increasing the size of a segment, it is possible that the request cannot be satisfied. This directive provides functionality similar to the realloc() function in the Standard C Library.
