RTEMS 4.10.1 On-Line Library
Region Manager Directives
RTEMS Ada User's Guide
14.4: Directives
Region Manager REGION_CREATE - Create a region
Region Manager REGION_IDENT - Get ID of a region
Region Manager REGION_DELETE - Delete a region
Region Manager REGION_EXTEND - Add memory to a region
Region Manager REGION_GET_SEGMENT - Get segment from a region
Region Manager REGION_RETURN_SEGMENT - Return segment to a region
Region Manager REGION_GET_SEGMENT_SIZE - Obtain size of a segment
Region Manager REGION_RESIZE_SEGMENT - Change size of a segment
This section details the region manager's directives.
A subsection is dedicated to each of this manager's directives
and describes the calling sequence, related constants, usage,
and status codes.
