RTEMS Logo
RTEMS 4.10.1 On-Line Library
Partition Manager Building a Partition Attribute Set
13.2.2: Building a Partition Attribute Set
In general, an attribute set is built by a bitwise OR of the desired attribute components. The set of valid partition attributes is provided in the following table:
Attribute values are specifically designed to be mutually exclusive, therefore bitwise OR and addition operations are equivalent as long as each attribute appears exactly once in the component list. An attribute listed as a default is not required to appear in the attribute list, although it is a good programming practice to specify default attributes. If all defaults are desired, the attribute RTEMS.DEFAULT_ATTRIBUTES should be specified on this call. The attribute_set parameter should be RTEMS.GLOBAL to indicate that the partition is to be known globally.
