RTEMS Logo
RTEMS 4.10.1 On-Line Library
Message Manager MESSAGE_QUEUE_GET_NUMBER_PENDING - Get number of messages pending on a queue
10.4.8: MESSAGE_QUEUE_GET_NUMBER_PENDING - Get number of messages pending on a queue
CALLING SEQUENCE:
procedure Message_Queue_Get_Number_Pending (
   ID     : in     RTEMS.ID;
   Count  :    out RTEMS.Unsigned32;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - number of messages pending returned successfully
RTEMS.INVALID_ADDRESS - count is NULL
RTEMS.INVALID_ID - invalid queue id
DESCRIPTION:
This directive returns the number of messages pending on this message queue in count. If no messages are present on the queue, count is set to zero.
NOTES:
Getting the number of pending messages on a global message queue which does not reside on the local node will generate a request to the remote node to actually obtain the pending message count for the specified message queue.
