RTEMS Logo
RTEMS 4.10.1 On-Line Library
Clock Manager CLOCK_GET_UPTIME - Get the time since boot
7.4.8: CLOCK_GET_UPTIME - Get the time since boot
CALLING SEQUENCE:
procedure Clock_Get_Uptime (
   Uptime :    out RTEMS.Timespec;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - clock tick processed successfully
RTEMS.INVALID_ADDRESS - time_buffer is NULL
DESCRIPTION:
This directive returns the seconds and nanoseconds since the system was booted. If the BSP supports nanosecond clock accuracy, the time reported will probably be different on every call.
NOTES:
This directive may be called from an ISR.
