RTEMS Logo
RTEMS 4.10.1 On-Line Library
Interrupt Manager INTERRUPT_FLASH - Flash Interrupts
6.4.4: INTERRUPT_FLASH - Flash Interrupts
CALLING SEQUENCE:
procedure Interrupt_Flash (
   Level : in     RTEMS.ISR_Level
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive temporarily enables maskable interrupts to the level which was returned by a previous call to rtems.interrupt_disable. Immediately prior to invoking this directive, maskable interrupts should be disabled by a call to rtems.interrupt_disable and will be redisabled when this directive returns to the caller.
NOTES:
This directive will not cause the calling task to be preempted.
