Getting Started with GNAT/RTEMS
This section describes how to configure and build RTEMS so that it is specifically tailored for your BSP (Board Support Package) and the CPU model it uses. There is currently only one supported method to compile and install RTEMS:
configure and make
Direct invocation of configure and make provides more control
and easier recovery from problems when building.
This section describes how to build RTEMS.
