RTEMS Logo
RTEMS 4.10.0 On-Line Library
Add <INSTALL_POINT>/bin to Executable PATH
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
4.4: Add <INSTALL_POINT>/bin to Executable PATH
In order to compile RTEMS, you must have the cross compilation toolset in your search path. It is important to have the RTEMS toolset first in your path to ensure that you are using the intended version of all tools. The following command prepends the directory where the tools were installed in a previous step:
export PATH=<INSTALL_POINT>/bin:${PATH}
NOTE: The above command is in Bourne shell (sh) syntax and should work with the Korn (ksh) and GNU Bourne Again Shell (bash). It will not work with the C Shell (csh) or derivatives of the C Shell.
