RTEMS Logo
RTEMS 4.10.0 On-Line Library
Solaris 2.x
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
3.4.1: Solaris 2.x
The build scripts are written in "shell". The program /bin/sh on Solaris 2.x is not robust enough to execute these scripts. If you are on a Solaris 2.x host, then change the first line of the files bit_ada, bit_gdb, and bit_rtems to use the /bin/ksh shell instead.
