RTEMS Logo
RTEMS 4.10.0 On-Line Library
Running the bit_ada Script
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
3.12: Running the bit_ada Script
After the bit_ada script has been modified to reflect the local installation, the modified bit_ada script is run using the following sequence:
cd tools
./bit_ada <target configuration>
Where <target configuration> is one of the following:
NOTE: The above list of target configurations is the list of RTEMS supported targets. Only a subset of these have been tested with GNAT/RTEMS. For more information, contact your GNAT/RTEMS representative.
The build process can take a while to complete. Many users find it handy to run the build process in the background, capture the output in a file, and monitor the output. This can be done as follows:
./bit_ada <target configuration> >bit.log 2>&1 &
tail -f bit.log
If no errors are encountered, the bit_ada script will conclude by printing messages similar to the following:
The src and build-i386-tools subdirectory may now be removed.
Started:  Fri Apr 10 10:14:07 CDT 1998
Finished: Fri Apr 10 12:01:33 CDT 1998
If the bit_ada script successfully completes, then the GNU C/C++ cross compilation tools are installed.
If the bit_ada script does not successfully complete, then investigation will be required to determine the source of the error.
