RTEMS Logo
RTEMS 4.10.0 On-Line Library
Apply RTEMS Patch to newlib
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
3.8: Apply RTEMS Patch to newlib
Apply the patch using the following command sequence:
cd tools/newlib-1.8.2
zcat ../../archive/newlib-1.8.2-rtems-20000606.diff.gz | patch -p1
Check to see if any of these patches have been rejected using the following sequence:
find . -name "*.rej" -print
If any files are found with the .rej extension, a patch has been rejected. This should not happen with a good patch file which is properly applied.
