RTEMS Logo
RTEMS 4.10.0 On-Line Library
Create the Archive and Build Directories
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
3.1: Create the Archive and Build Directories
Start by making the archive directory to contain the downloaded source code and the tools directory to be used as a build directory. The command sequence to do this is shown below:
mkdir archive
mkdir tools
This will result in an initial directory structure similar to the one shown in the following figure:
/whatever/prefix/you/choose/
        archive/
        tools/
