RTEMS Logo
RTEMS 4.10.0 On-Line Library
Introduction
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
Chapter 1: Introduction
  • Real-Time Embedded Systems
  • Cross Development
  • Resources on the Internet
  • The purpose of this document is to guide you through the process of installing a GNU cross development environment to use with RTEMS.
    If you are already familiar with the concepts behind a cross compiler and have a background in Unix, these instructions should provide the bare essentials for performing a setup of the following items:
    The remainder of this chapter provides background information on real-time embedded systems and cross development and an overview of other resources of interest on the Internet. If you are not familiar with real-time embedded systems or the other areas, please read those sections. These sections will help familiarize you with the types of systems RTEMS is designed to be used in and the cross development process used when developing RTEMS applications.
