bcmp - Compare two memory areas
bcopy - Copy memory regions
bzero - Initialize memory to zero
index - Search for character in string
memchr - Find character in memory
memcmp - Compare two memory areas
memcpy - Copy memory regions
memmove - Move possibly overlapping memory
memset - Set an area of memory
rindex - Reverse search for character in string
strcasecmp - Compare strings ignoring case
strcat - Concatenate strings
strchr - Search for character in string
strcmp - Character string compare
strcoll - Locale specific character string compare
strcpy - Copy string
strcspn - Count chars not in string
strerror - Convert error number to string
strlen - Character string length
strlwr - Convert string to lower case
strncasecmp - Compare strings ignoring case
strncat - Concatenate strings
strncmp - Character string compare
strncpy - Counted copy string
strpbrk - Find chars in string
strrchr - Reverse search for character in string
strspn - Find initial match
strstr - Find string segment
strtok - Get next token from a string
strupr - Convert string to upper case
strxfrm - Transform string
