RTEMS Logo
RTEMS 4.10.0 On-Line Library
Thread Manager pthread_getschedparam - Get Thread Scheduling Parameters
PREV UP next Bookshelf RTEMS POSIX API User's Guide
17.4.25: pthread_getschedparam - Get Thread Scheduling Parameters
CALLING SEQUENCE:
#include <pthread.h>
int pthread_getschedparam(
  pthread_t           thread,
  int                *policy,
  struct sched_param *param
STATUS CODES:
EINVAL
The policy pointer argument is invalid.
EINVAL
The scheduling parameters pointer argument is invalid.
ESRCH
The thread indicated by the parameter thread is invalid.
DESCRIPTION:
The pthread_getschedparam routine is used to obtain the scheduler policy and parameters associated with thread. The current policy and associated parameters values returned in policy and param, respectively.
NOTES:
As required by POSIX, RTEMS defines the feature symbol _POSIX_THREAD_PRIORITY_SCHEDULING to indicate that the family of routines to which this routine belongs is supported.
