RTEMS Logo
RTEMS 4.10.0 On-Line Library
Thread Manager pthread_once - Dynamic Package Initialization
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
17.4.23: pthread_once - Dynamic Package Initialization
CALLING SEQUENCE:
#include <pthread.h>
pthread_once_t once_control = PTHREAD_ONCE_INIT;
int pthread_once(
   pthread_once_t   *once_control,
   void            (*init_routine)(void)
STATUS CODES:
NONE
DESCRIPTION:
The pthread_once routine is used to provide controlled initialization of variables. The first call to pthread_once by any thread with the same once_control will result in the init_routine being invoked with no arguments. Subsequent calls to pthread_once with the same once_control will have no effect.
The init_routine is guaranteed to have run to completion when this routine returns to the caller.
NOTES:
The behavior of pthread_once is undefined if once_control is automatic storage (i.e. on a task stack) or is not initialized using PTHREAD_ONCE_INIT.
