RTEMS Logo
RTEMS 4.10.0 On-Line Library
Thread Manager pthread_attr_setschedparam - Set Scheduling Parameters
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
17.4.15: pthread_attr_setschedparam - Set Scheduling Parameters
CALLING SEQUENCE:
#include <pthread.h>
int pthread_attr_setschedparam(
  pthread_attr_t           *attr,
  const struct sched_param  param
STATUS CODES:
EINVAL
The attribute pointer argument is invalid.
EINVAL
The attribute set is not initialized.
EINVAL
The specified scheduler parameter argument is invalid.
DESCRIPTION:
The pthread_attr_setschedparam routine is used to set the scheduler parameters field in the thread attribute object attr to the value specified by param.
NOTES:
As required by POSIX, RTEMS defines the feature symbol _POSIX_THREAD_PRIORITY_SCHEDULING to indicate that the family of routines to which this routine belongs is supported.
