#include <pthread.h> int pthread_attr_setschedpolicy( pthread_attr_t *attr, int policy );
The pthread_attr_setschedpolicy
routine is used to set the
scheduler policy field in the thread attribute object attr
to
the value specified by policy
Scheduling policies may be one of the following:
SCHED_DEFAULT
SCHED_FIFO
SCHED_RR
SCHED_SPORADIC
SCHED_OTHER
The precise meaning of each of these is discussed elsewhere in this manual.
As required by POSIX, RTEMS defines the feature symbol
_POSIX_THREAD_PRIORITY_SCHEDULING
to indicate that the
family of routines to which this routine belongs is supported.
