RTEMS Logo
RTEMS 4.10.0 On-Line Library
Thread Manager pthread_attr_setscope - Set Thread Scheduling Scope
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
17.4.9: pthread_attr_setscope - Set Thread Scheduling Scope
CALLING SEQUENCE:
#include <pthread.h>
int pthread_attr_setscope(
  pthread_attr_t *attr,
  int             contentionscope
STATUS CODES:
EINVAL
The attribute pointer argument is invalid.
EINVAL
The attribute set is not initialized.
EINVAL
The contention scope specified is not valid.
ENOTSUP
The contention scope specified (PTHREAD_SCOPE_SYSTEM) is not supported.
DESCRIPTION:
The pthread_attr_setscope routine is used to set the contention scope field in the thread attribute object attr to the value specified by contentionscope.
The contentionscope must be either PTHREAD_SCOPE_SYSTEM to indicate that the thread is to be within system scheduling contention or PTHREAD_SCOPE_PROCESS indicating that the thread is to be within the process scheduling contention scope.
NOTES:
As required by POSIX, RTEMS defines the feature symbol _POSIX_THREAD_PRIORITY_SCHEDULING to indicate that the family of routines to which this routine belongs is supported.
