RTEMS Logo
RTEMS 4.10.0 On-Line Library
Thread Manager pthread_attr_setstacksize - Set Thread Stack Size
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
17.4.5: pthread_attr_setstacksize - Set Thread Stack Size
CALLING SEQUENCE:
#include <pthread.h>
int pthread_attr_setstacksize(
  pthread_attr_t *attr,
  size_t          stacksize
STATUS CODES:
EINVAL
The attribute pointer argument is invalid.
EINVAL
The attribute set is not initialized.
DESCRIPTION:
The pthread_attr_setstacksize routine is used to set the stacksize attribute in the attr thread attribute object.
NOTES:
As required by POSIX, RTEMS defines the feature symbol _POSIX_THREAD_ATTR_STACKSIZE to indicate that this routine is supported.
If the specified stacksize is below the minimum required for this CPU (PTHREAD_STACK_MIN, then the stacksize will be set to the minimum for this CPU.
