RTEMS Logo
RTEMS 4.10.0 On-Line Library
Thread Manager pthread_attr_setdetachstate - Set Detach State
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
17.4.3: pthread_attr_setdetachstate - Set Detach State
CALLING SEQUENCE:
#include <pthread.h>
int pthread_attr_setdetachstate(
  pthread_attr_t *attr,
  int             detachstate
STATUS CODES:
EINVAL
The attribute pointer argument is invalid.
EINVAL
The attribute set is not initialized.
EINVAL
The detachstate argument is invalid.
DESCRIPTION:
The pthread_attr_setdetachstate routine is used to value of the detachstate attribute. This attribute controls whether the thread is created in a detached state.
The detachstate can be either PTHREAD_CREATE_DETACHED or PTHREAD_CREATE_JOINABLE. The default value for all threads is PTHREAD_CREATE_JOINABLE.
NOTES:
If a thread is in a detached state, then the use of the ID with the pthread_detach or pthread_join routines is an error.
