RTEMS Logo
RTEMS 4.10.0 On-Line Library
Message Passing Manager Message Queues
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
16.2.3: Message Queues
Message queues are named objects similar to the pipes of POSIX. They are a means of communicating data between multiple processes and for passing messages among tasks and ISRs. Message queues can contain a variable number of messages from 0 to an upper limit that is user defined. The maximum length of the message can be set on a per message queue basis. Normally messages are sent and received from the message queue in FIFO order. However, messages can also be prioritized and a priority queue established for the passing of messages. Synchronization is needed when a task waits for a message to arrive at a queue. Also, a task may poll a queue for the arrival of a message.
The message queue descriptor mqd_t represents the message queue. It is passed as an argument to all of the message queue functions.
