RTEMS Logo
RTEMS 4.10.0 On-Line Library
Memory Management Manager Directives
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
12.4: Directives
  • Memory Management Manager mlockall - Lock the Address Space of a Process
  • Memory Management Manager munlockall - Unlock the Address Space of a Process
  • Memory Management Manager mlock - Lock a Range of the Process Address Space
  • Memory Management Manager munlock - Unlock a Range of the Process Address Space
  • Memory Management Manager mmap - Map Process Addresses to a Memory Object
  • Memory Management Manager munmap - Unmap Previously Mapped Addresses
  • Memory Management Manager mprotect - Change Memory Protection
  • Memory Management Manager msync - Memory Object Synchronization
  • Memory Management Manager shm_open - Open a Shared Memory Object
  • Memory Management Manager shm_unlink - Remove a Shared Memory Object
  • This section details the memory management manager's directives. A subsection is dedicated to each of this manager's directives and describes the calling sequence, related constants, usage, and status codes.
