RTEMS Logo
RTEMS 4.10.0 On-Line Library
Semaphore Manager sem_post - Unlock a Semaphore
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
9.4.9: sem_post - Unlock a Semaphore
CALLING SEQUENCE:
int sem_post(
  sem_t *sem
STATUS CODES:
EINVAL
The sem argument does not refer to a valid semaphore
DESCRIPTION:
This function attempts to release the semaphore specified by sem. If other tasks are waiting on the semaphore, then one of those tasks (which one depends on the scheduler being used) is allowed to lock the semaphore and return from its sem_wait(), sem_trywait(), or sem_timedwait() call. If there are no other tasks waiting on the semaphore, then the semaphore value is simply incremented. sem_post() returns 0 upon successful completion.
If an error occurs, the function returns -1 and sets errno to the appropriate error code.
NOTES:
Multiprocessing is not supported in this implementation.
