RTEMS Logo
RTEMS 4.10.0 On-Line Library
Device- and Class- Specific Functions Manager cfsetispeed - Sets terminal input baud rate
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
6.4.3: cfsetispeed - Sets terminal input baud rate
CALLING SEQUENCE:
#include <termios.h>
int cfsetispeed(
  struct termios *p,
  speed_t         speed
STATUS CODES:
The cfsetispeed() function returns a zero when successful and returns -1 when an error occurs.
DESCRIPTION:
The cfsetispeed() function stores a code for the terminal speed stored in a struct termios. The codes are defined in <termios.h> by the macros B0, B50, B75, B110, B134, B150, B200, B300, B600, B1200, B1800, B2400, B4800, B9600, B19200, and B38400.
NOTES:
This function merely stores a value in the termios structure. It does not change the terminal speed until a tcsetattr() is done. It does not detect impossible terminal speeds.
