#include <unistd.h> int pathconf( const char *path, int name );
path was not a directory whan a
directory was expected.
pathconf() gets a value for the configuration option name
for the open file descriptor filedes.
The possible values for name are:
filedes or
path refer to a directory, then the value applies to the whole
directory. The corresponding macro is _POSIX_LINK_MAX.
filedes
or path must refer to a terminal. The corresponding macro is
_POSIX_MAX_CANON.
filedes or
_POSIX_MAX_INPUT.
path or
filedes. The process is allowed to create. The corresponding macro
is _POSIX_NAME_MAX.
path or
filedes is the current working directory. The corresponding macro
is _POSIX_PATH_MAX.
filedes must refer to a
pipe or FIFO and path must refer to a FIFO. The corresponding macro
is _POSIX_PIPE_BUF.
filedes or path refer to a directory, then this applies to all
files in that directory. The corresponding macro is
_POSIX_CHOWN_RESTRICTED.
Files with name lengths longer than the value returned for name equal
_PC_NAME_MAX may exist in the given directory.
