RTEMS Logo
RTEMS 4.10.0 On-Line Library
Files and Directories Manager mkfifo - Makes a FIFO special file
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
4.4.17: mkfifo - Makes a FIFO special file
CALLING SEQUENCE:
#include <sys/types.h>
#include <sys/stat.h>
int mkfifo(
  const char *path,
  mode_t      mode
STATUS CODES:
EACCES
Search permission is denied for a directory in a file's path prefix
EEXIST
The named file already exists.
ENOENT
A file or directory does not exist.
ENOSPC
No space left on disk.
ENOTDIR
A component of the specified path was not a directory when a directory was expected.
EROFS
Read-only file system.
DESCRIPTION:
The mkfifo() function creates a new FIFO special file named path. The permission bits (modified by the file creation mask) are set from mode. The owner and group IDs for the FIFO are set from the efective user ID and group ID.
NOTES:
NONE
