#include <sys/types.h> #include <sys/stat.h> #include <fcntl.h> int creat( const char *path, mode_t mode );
path
already exists and O_CREAT and O_EXCL were used.
path
refers to a directory and the access requested involved
writing
path
refers to an executable image which is currently being
executed and write access was requested
path
points outside your accessible address space
path
did not allow search (execute) permission.
path
was too long.
path
does not exist or is a dangling
symbolic link.
path
is not, in fact, a
directory.
path
refers to a file on a read-only filesystem and write access
was requested
creat
attempts to create a file and return a file descriptor for
use in read, write, etc.
NONE
The routine is implemented in Cygnus newlib.
