The files and directories manager is ...
The directives provided by the files and directories manager are:
opendir - Open a Directory
readdir - Reads a directory
rewinddir - Resets the readdir() pointer
scandir - Scan a directory for matching entries
telldir - Return current location in directory stream
closedir - Ends directory read operation
getdents - Get directory entries
chdir - Changes the current working directory
fchdir - Changes the current working directory
getcwd - Gets current working directory
open - Opens a file
creat - Create a new file or rewrite an existing one
umask - Sets a file creation mask
link - Creates a link to a file
symlink - Creates a symbolic link to a file
readlink - Obtain the name of the link destination
mkdir - Makes a directory
mkfifo - Makes a FIFO special file
unlink - Removes a directory entry
rmdir - Delete a directory
rename - Renames a file
stat - Gets information about a file.
fstat - Gets file status
lstat - Gets file status
access - Check permissions for a file.
chmod - Changes file mode
fchmod - Changes permissions of a file
chown - Changes the owner and/ or group of a file
utime - Change access and/or modification times of an inode
ftruncate - Truncate a file to a specified length
pathconf - Gets configuration values for files
fpathconf - Get configuration values for files
mknod - Create a directory
