RTEMS Logo
RTEMS 4.10.0 On-Line Library
Signal Manager Signal Delivery
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
2.2.2: Signal Delivery
Signals which are directed at a thread are delivered to the specified thread.
Signals which are directed at a process are delivered to a thread which is selected based on the following algorithm:
  1. If the action for this signal is currently SIG_IGN, then the signal is simply ignored.
  2. If the currently executing thread has the signal unblocked, then the signal is delivered to it.
  3. If any threads are currently blocked waiting for this signal (sigwait()), then the signal is delivered to the highest priority thread waiting for this signal.
  4. If any other threads are willing to accept delivery of the signal, then the signal is delivered to the highest priority thread of this set. In the event, multiple threads of the same priority are willing to accept this signal, then priority is given first to ready threads, then to threads blocked on calls which may be interrupted, and finally to threads blocked on non-interruptible calls.
  5. In the event the signal still can not be delivered, then it is left pending. The first thread to unblock the signal (sigprocmask() or pthread_sigprocmask()) or to wait for this signal (sigwait()) will be the recipient of the signal.
