RTEMS 4.10.0 On-Line Library
Cable Faults
RTEMS Network Supplement
4.6.3: Cable Faults
- Run the
netdemo program.
- Issue a `
u' console command to make the target machine transmit
a bunch of UDP packets.
- While the packets are being transmitted, disconnect and reconnect the
network cable.
- Display the network statistics and verify that the driver has
detected the loss of carrier.
- Verify that you can still telnet to both ports on the target machine.
