There are a number of command available in the shell / monitor to aid in tracing the behavior of the network stack. The following is a list of them:
inet
This command shows the current routing information for the TCP/IP stack. Following is an example showing the output of this command.
Destination Gateway/Mask/Hw Flags Refs Use Expire Interface 10.0.0.0 255.0.0.0 U 0 0 17 smc1 127.0.0.1 127.0.0.1 UH 0 0 0 lo0
In this example, there is only one network interface with an IP address of 10.8.1.1. This link is currently not up.
Two routes that are shown are the default routes for the Ethernet interface (10.0.0.0) and the loopback interface (127.0.0.1).
Since the stack comes from BSD, this command is very similar to the netstat command. For more details on the network routing please look the following URL: (http://www.freebsd.org/doc/en_US.ISO8859-1/books/handbook/network-routing.html)
For a quick reference to the flags, see the table below:
U'
H'
G'
S'
C'
W'
L'
mbuf
This command shows the current MBUF statistics. An example of the command is shown below:
************ MBUF STATISTICS ************
mbufs:4096 clusters: 256 free: 241
drops: 0 waits: 0 drains: 0
free:4080 data:16 header:0 socket:0
pcb:0 rtable:0 htable:0 atable:0
soname:0 soopts:0 ftable:0 rights:0
ifaddr:0 control:0 oobdata:0
if
This command shows the current statistics for your Ethernet driver as long as the ioctl hook
SIO_RTEMS_SHOW_STATS has been implemented. Below is an example:
************ INTERFACE STATISTICS ************
***** smc1 *****
Ethernet Address: 00:12:76:43:34:25
Address:10.8.1.1 Broadcast Address:10.255.255.255 Net mask:255.0.0.0
Flags: Up Broadcast Running Simplex
Send queue limit:50 length:0 Dropped:0
SMC91C111 RTEMS driver A0.01 11/03/2002 Ian Caddy (ianc@microsol.iinet.net.au)
Rx Interrupts:0 Not First:0 Not Last:0
Giant:0 Runt:0 Non-octet:0
Bad CRC:0 Overrun:0 Collision:0
Tx Interrupts:2 Deferred:0 Missed Hearbeat:0
No Carrier:0 Retransmit Limit:0 Late Collision:0
Underrun:0 Raw output wait:0 Coalesced:0
Coalesce failed:0 Retries:0
***** lo0 *****
Address:127.0.0.1 Net mask:255.0.0.0
Flags: Up Loopback Running Multicast
ip
This command show the IP statistics for the currently configured interfaces.
icmp
This command show the ICMP statistics for the currently configured interfaces.
tcp
This command show the TCP statistics for the currently configured interfaces.
udp
This command show the UDP statistics for the currently configured interfaces.
