RTEMS 4.10.0 On-Line Library
Write the Driver IOCTL Function
RTEMS Network Supplement
2.11: Write the Driver IOCTL Function
This function handles ioctl requests directed at the device. The ioctl
commands which must be handled are:
SIOCGIFADDR
SIOCSIFADDR
If the device is an Ethernet interface these
commands should be passed on to
ether_ioctl.
SIOCSIFFLAGS
This command should be used to start or stop the device,
depending on the state of the interface
IFF_UP and
IFF_RUNNING bits in if_flags:
IFF_RUNNING
Stop the device.
IFF_UP
Start the device.
IFF_UP|IFF_RUNNING
Stop then start the device.
0
Do nothing.
