RTEMS Logo
RTEMS 4.10.0 On-Line Library
SPARC Specific Information Interrupt Levels
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
11.4.4: Interrupt Levels
Sixteen levels (0-15) of interrupt priorities are supported by the SPARC architecture with level fifteen (15) being the highest priority. Level zero (0) indicates that interrupts are fully enabled. Interrupt requests for interrupts with priorities less than or equal to the current interrupt mask level are ignored.
Although RTEMS supports 256 interrupt levels, the SPARC only supports sixteen. RTEMS interrupt levels 0 through 15 directly correspond to SPARC processor interrupt levels. All other RTEMS interrupt levels are undefined and their behavior is unpredictable.
