RTEMS Logo
RTEMS 4.10.0 On-Line Library
SPARC Specific Information Non-Floating Point Registers
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
11.2.1.1: Non-Floating Point Registers
The SPARC architecture defines thirty-two non-floating point registers directly visible to the programmer. These are divided into four sets:
Each register is referred to by either two or three names in the SPARC reference manuals. First, the registers are referred to as r0 through r31 or with the alternate notation r[0] through r[31]. Second, each register is a member of one of the four sets listed above. Finally, some registers have an architecturally defined role in the programming model which provides an alternate name. The following table describes the mapping between the 32 registers and the register sets:
Register Number Register Names Description
0 - 7 g0 - g7 Global Registers
8 - 15 o0 - o7 Output Registers
16 - 23 l0 - l7 Local Registers
24 - 31 i0 - i7 Input Registers
As mentioned above, some of the registers serve defined roles in the programming model. The following table describes the role of each of these registers:
Register Name Alternate Name Description
g0 NA reads return 0 ; writes are ignored
o6 sp stack pointer
i6 fp frame pointer
i7 NA return address
