RTEMS Logo
RTEMS 4.10.0 On-Line Library
SPARC Specific Information Register Usage
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
11.2.5: Register Usage
As discussed above, the call instruction does not automatically save any registers. The save and restore instructions are used to allocate and deallocate register windows. When a register window is allocated, the new set of local registers are available for the exclusive use of the subroutine which allocated this register set.
