RTEMS CPU Architecture Supplement
If this PowerPC implementation supports on-chip caching and this is to be utilized, then it should be enabled during the reset application initialization code. On-chip caching has been observed to prevent some emulators from working properly, so it may be necessary to run with caching disabled to use these emulators.
In addition to the requirements described in the
Board Support Packages chapter of the RTEMS C
Applications User's Manual for the reset code
which is executed before the call to rtems_initialize_executive
the PowrePC version has the following specific requirements:
