RTEMS Logo
RTEMS 4.10.0 On-Line Library
PowerPC Specific Information Flat Memory Model
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
9.3.1: Flat Memory Model
The PowerPC architecture supports a variety of memory models. RTEMS supports the PowerPC using a flat memory model with paging disabled. In this mode, the PowerPC automatically converts every address from a logical to a physical address each time it is used. The PowerPC uses information provided in the Block Address Translation (BAT) to convert these addresses.
Implementations of the PowerPC architecture may be thirty-two or sixty-four bit. The PowerPC architecture supports a flat thirty-two or sixty-four bit address space with addresses ranging from 0x00000000 to 0xFFFFFFFF (4 gigabytes) in thirty-two bit implementations or to 0xFFFFFFFFFFFFFFFF in sixty-four bit implementations. Each address is represented by either a thirty-two bit or sixty-four bit value and is byte addressable. The address may be used to reference a single byte, half-word (2-bytes), word (4 bytes), or in sixty-four bit implementations a doubleword (8 bytes). Memory accesses within the address space are performed in big or little endian fashion by the PowerPC based upon the current setting of the Little-endian mode enable bit (LE) in the Machine State Register (MSR). While the processor is in big endian mode, memory accesses which are not properly aligned generate an "alignment exception" (vector offset 0x00600). In little endian mode, the PowerPC architecture does not require the processor to generate alignment exceptions.
The following table lists the alignment requirements for a variety of data accesses:
Data Type Alignment Requirement
byte 1
half-word 2
word 4
doubleword 8
Doubleword load and store operations are only available in PowerPC CPU models which are sixty-four bit implementations.
RTEMS does not directly support any PowerPC Memory Management Units, therefore, virtual memory or segmentation systems involving the PowerPC are not supported.
