RTEMS Logo
RTEMS 4.10.0 On-Line Library
PowerPC Specific Information Debug Model
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
9.1.9: Debug Model
  • PowerPC Specific Information Low Power Model
  • The macro PPC_DEBUG_MODEL is set to indicate the debug support features present in this CPU model. The following debug support feature sets are currently supported:
    PPC_DEBUG_MODEL_STANDARD
    indicates that the single-step trace enable (SE) and branch trace enable (BE) bits in the MSR are supported by this CPU model.
    PPC_DEBUG_MODEL_SINGLE_STEP_ONLY
    indicates that only the single-step trace enable (SE) bit in the MSR is supported by this CPU model.
    PPC_DEBUG_MODEL_IBM4xx
    indicates that the debug exception enable (DE) bit in the MSR is supported by this CPU model. At this time, this particular debug feature set has only been seen in the IBM 4xx series.
