RTEMS Logo
RTEMS 4.10.0 On-Line Library
PowerPC Specific Information Has Double Precision Floating Point
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
9.1.4: Has Double Precision Floating Point
The macro PPC_HAS_DOUBLE is set to 1 to indicate that the PowerPC model has support for double precision floating point numbers. This is important because the floating point registers need only be four bytes wide (not eight) if double precision is not supported.
