RTEMS Logo
RTEMS 4.10.0 On-Line Library
Intel/AMD x86 Specific Information Flat Memory Model
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
5.3.1: Flat Memory Model
RTEMS supports the i386 protected mode, flat memory model with paging disabled. In this mode, the i386 automatically converts every address from a logical to a physical address each time it is used. The i386 uses information provided in the segment registers and the Global Descriptor Table to convert these addresses. RTEMS assumes the existence of the following segments:
The i386 segment registers and associated selectors must be initialized when the initialize_executive directive is invoked. RTEMS treats the segment registers as system registers and does not modify or context switch them.
This i386 memory model supports a flat 32-bit address space with addresses ranging from 0x00000000 to 0xFFFFFFFF (4 gigabytes). Each address is represented by a 32-bit value and is byte addressable. The address may be used to reference a single byte, half-word (2-bytes), or word (4 bytes).
