RTEMS Logo
RTEMS 4.10.0 On-Line Library
ARM Specific Information Interrupt Levels
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
2.4.1: Interrupt Levels
The RTEMS interrupt level mapping scheme for the ARM is not a numeric level as on most RTEMS ports. It is a bit mapping that corresponds the enable bit postions in the Current Program Status Register (CPSR). There are only two levels: IRQ enabled and IRQ disabled.
