RTEMS Logo
RTEMS 4.10.0 On-Line Library
Port Specific Information Register Usage
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
1.2.2: Register Usage
In each of the architecture specific chapters, this subsection will detail the set of registers which are NOT preserved across subroutine invocations. The registers which are not preserved are assumed to be available for use as scratch registers. Therefore, the contents of these registers should not be assumed upon return from any RTEMS directive.
In some architectures, there may be a set of registers made available automatically as a side-effect of the subroutine invocation mechanism.
