RTEMS Logo
RTEMS 4.10.0 On-Line Library
Port Specific Information Floating Point Unit
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
1.1.2: Floating Point Unit
In most architectures, the presence of a floating point unit is an option. It does not matter whether the hardware floating point support is incorporated on-chip or is an external coprocessor as long as it appears an FPU per the ISA. However, if a hardware FPU is not present, it is possible that the floating point emulation library for this CPU is not reentrant and thus context switched by RTEMS.
RTEMS provides two feature macros to indicate the FPU configuration:
