RTEMS Logo
RTEMS 4.10.0 On-Line Library
Preface
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
Preface
The Real Time Executive for Multiprocessor Systems (RTEMS) is designed to be portable across multiple processor architectures. However, the nature of real-time systems makes it essential that the application designer understand certain processor dependent implementation details. These processor dependencies include calling convention, board support package issues, interrupt processing, exact RTEMS memory requirements, performance data, header files, and the assembly language interface to the executive.
Each architecture represents a CPU family and usually there are a wide variety of CPU models within it. These models share a common Instruction Set Architecture (ISA) which often varies based upon some well-defined rules. There are often multiple implementations of the ISA and these may be from one or multiple vendors.
On top of variations in the ISA, there may also be variations which occur when a CPU core implementation is combined with a set of peripherals to form a system on chip. For example, there are many ARM CPU models from numerous semiconductor vendors and a wide variety of peripherals. But at the ISA level, they share a common compatibility.
RTEMS depends upon this core similarity across the CPU models and leverages that to minimize the source code that is specific to any particular CPU core implementation or CPU model.
This manual is separate and distinct from the RTEMS Porting Guide. That manual is a guide on porting RTEMS to a new architecture. This manual is focused on the more mundane CPU architecture specific issues that may impact application development. For example, if you need to write a subroutine in assembly language, it is critical to understand the calling conventions for the target architecture.
The first chapter in this manual describes these issues in general terms. In a sense, it is posing the questions one should be aware may need to be answered and understood when porting an RTEMS application to a new architecture. Each subsequent chapter gives the answers to those questions for a particular CPU architecture.
