RTEMS Logo
RTEMS 4.10.0 On-Line Library
Chains Multi-threading
PREV UP NEXT Bookshelf RTEMS C User's Guide
28.3.1: Multi-threading
Chains are designed to be used in a multi-threading environment. The directives list which operations mask interrupts. Chains supports tasks and interrupt service routines appending and extracting nodes with out the need for extra locks. Chains how-ever cannot insure the integrity of a chain for all operations. This is the responsibility of the user. For example an interrupt service routine extracting nodes while a task is iterating over the chain can have unpredictable results.
