RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services Decomposing and Recomposing an Object Id
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.3.1: Decomposing and Recomposing an Object Id
Services are provided to decompose an object Id into its subordinate components. The following services are used to do this:
The following C language example illustrates the decomposition of an Id and printing the values.
void printObjectId(rtems_id id)
  printf(
    "API=%d Class=%d Node=%d Index=%d\n",
    rtems_object_id_get_api(id),
    rtems_object_id_get_class(id),
    rtems_object_id_get_node(id),
    rtems_object_id_get_index(id)
This prints the components of the Ids as integers.
It is also possible to construct an arbitrary Id using the rtems_build_id service. The following C language example illustrates how to construct the "next Id."
rtems_id nextObjectId(rtems_id id)
  return rtems_build_id(
    rtems_object_id_get_index(id) + 1
Note that this Id may not be valid in this system or associated with an allocated object.
